ideas to fill torneau holes
Page 1 of 1 [ 10 posts ]
 Post subject: ideas to fill torneau holes
Posted: Sun Nov 06, 2011 10:12 pm
Ride: el xr8
hi guys
just bought an xh ute. plenty to be done. but first up im geting a hard cover so i will want to remove the torneau cover latches. can i get any advise ir is there a tech doc.
cheers
Thats a sweet ride you got there! don't tuch it, dont even look at it
Now a soon to be sliper xh ute simple yet elegant
I did have a el xr8
Mum's BF xr8 ute with sports exhaust
 Post subject: Re: ideas to fill torneau holes
Posted: Mon Nov 07, 2011 10:37 am
Ride: Ford
Alot of people weld the holes up then smooth them off and respray....If done right you will never even know the holes were ever there.
Posted: Mon Nov 07, 2011 11:40 am
Ride: el xr8
weld. ok ill have to do some practice. what do you recone off bog
I did have a el xr8
Posted: Mon Nov 07, 2011 12:28 pm
Ride: Ford
Bog will work but over time it will crack and fall out leaving the holes exposed so in the end it will have been a waste of time. Welding them up is the only real way of fixing them forever.
Posted: Mon Nov 07, 2011 6:42 pm
Ride: AUII XR6 Uterus
I would get some beat up old car panels to try welding on first, see first hand how much damage you can do with the slightest bit too much heat like Ash mentioned.
Posted: Mon Nov 07, 2011 7:10 pm
Ride: XH
NT, Australia
Utes that come with hard lids from the factory have little plugs that are coloured to match. They aren't the best option cause you can easily see them but won't be as obvious as the clips you have now. Much safer than stuffing up the welding too.
They are on ebay from time to time and I think you can buy them from Ford dealers, I imagine BA etc would still fit the XH.
Posted: Mon Nov 07, 2011 8:36 pm
Ride: XH
NT, Australia
Ash wrote:
You'd have to check the diameter. AU/BA/BF use a single rivet to hold their clips on. XD-XH use 3 plastic pins per clip that push in from the back.
My XG had 3 pins but my XH has the single rivet type. In any case checking the diameter would be good.
Posted: Mon Nov 07, 2011 10:54 pm
Ride: 96 XH/97 EL
Yeah, XHI's have the 3 hole attachment with a hook fitting, XHII's have a single one with a round fitting.
Probably best to improvise with the original fittings - maybe a body coloured plug.
Too much hassle and too much to go wrong filling/finishing the existing holes - probably should be left to a pro, $$$$ as well too.
Users browsing this forum: No registered users and 45 guests
It is currently Sun Nov 17, 2024 5:17 pm All times are UTC + 11 hours
