wild-el |
Hey guys I need a run down on how to remove the rear bar off the el. Need to take off the tow bar and I don't really want to root anything on there....
Do I have to take off the rear wheels?
_________________ EL xr6,standard a** au motor,hi-tech headers, 2 1/2inch red back,,Tikky kitted and wingless,Black GT-P's,on ultra lows and still too high |
TheELghia |
wild-el wrote: Hey guys I need a run down on how to remove the rear bar off the el. Need to take off the tow bar and I don't really want to root anything on there.... Do I have to take off the rear wheels? In the boot, lift up the mat and you should see 2 square rubber plugs at each corner. Pulling them out will reveal some bolts (14mm i think) for you to undo. You may have to take the wheels off to remove the inner guards, gaining access to another bold on each side. Then you have to hack off 3 rivits holding the bumper to the under side of the spare wheel tub. All thats left is pop 2 clips on either side of the bumper and slide her off. Someone correct me if im wrong. |
wild-el |
Thanks mate am getng stuck into it now.
Users browsing this forum: No registered users and 145 guests |
