1992 Ford EB Auto V8 Sedan
Page 1 of 1 [ 8 posts ]
 Post subject: 1992 Ford EB Auto V8 Sedan
Posted: Sat Feb 26, 2022 11:25 am
Ride: Ford Falcon EB
Hi on my 1992 EB V8 Sedan sometimes my auto transmission won't change into 2nd or 3rd, if I stop, turn off the engine and start over it seems to work ok after that, ,It doesn't do it all the time but more so when cold,, I must admit the auto transmission hasn't had its oiled changed since new, same with filter , oil looks ok...I was told it maybe a sensor on the transmission but not sure if that is right or not....also I have noticed recently it takes longer to change into 4th ...any ideas or suggestions.
 Post subject: Re: 1992 Ford EB Auto V8 Sedan
Posted: Sat Feb 26, 2022 4:23 pm
Online
not changing the transmission fluid since wayyy back then won't help you. however changing the fluid now 'may/may not' create more problems re slippage?. is the fluid a light red in colour or a dark red/black?.
Posted: Sat Feb 26, 2022 4:48 pm
The transmission fluid is more a light brown
Posted: Sat Feb 26, 2022 4:52 pm
Transmission doesn't really slip ,it goes from take off (1st) into second but won't change into third or at times changes into third but not fourth, I turn the power button / off but no difference,,, as I was saying in my post ,if I stop turn off the engine and take off again it normally goes normal... Just seems that stopping and turning off the engine fixes the problem
Posted: Sat Feb 26, 2022 9:01 pm
Online
may have sticky solenoids?.
Posted: Wed Apr 13, 2022 6:55 pm
EFI Guru
Gallery: 28 images
Do a trans Self Test.
Posted: Tue Apr 23, 2024 11:00 am
Everything usually proceeds as usual if I stop, turn off the motor, and start off again. It appears that the issue may be resolved by halting and shutting off the engine.
Posted: Wed Apr 24, 2024 1:13 pm
EFI Guru
Gallery: 28 images
Have you done the self test?
Users browsing this forum: Google Adsense [Bot] and 18 guests
It is currently Sun Jan 12, 2025 8:18 am All times are UTC + 11 hours
