1" Phenolic spacer and 80mm mass air flow sensor
Page 1 of 1 [ 10 posts ]
 Post subject: 1" Phenolic spacer and 80mm mass air flow sensor
Posted: Mon Jun 10, 2013 5:52 pm
Gallery: 9 images
Ride: 02 xls ute 347
I've got a half inch spacer on my explorer manifold now it's split do need a new one will a 1" spacer fit ünder my bonnet with out hitting it when it's reving ? Also what brand maf sensor should I get I'm going to get an 80 mm plastic one because I have a 75 mm throttle body and egr spacer. We're do I get one to suit an au falcon summit don't have one that goes straight onto the air box, is it important to get one suited to you injectors
02 series 3 AU marline ute 5speed 347 stroker
 Post subject: Re: 1" Phenolic spacer and 80mm mass air flow sensor
Posted: Thu Jul 04, 2013 10:08 pm
Ride: Fordrunner 5.0 Turbo
Pro-M mafs are supposed to be the ducks guts.
www.promracing.com for more info.
As for the spacer I got no idea. Most guys seem to run a 3/8" and call it a day. I have a 1" on order but my 5.0 is not in a falcon engine bay.
Posted: Mon Jul 08, 2013 9:53 pm
Gallery: 9 images
Cheers champ! I ended up going the 3
Quatre inch one stayed safe an i think I'm going to go the 90 mm lighting maf sensor which is on eBay for pretty cheap
Posted: Mon Jul 08, 2013 10:39 pm
Power: 274 rwkw
With the lightning, you will need an AU MAF plug, or the adapter. BPT sell it, as do SCT.
Brett
Member#1131
Posted: Tue Jul 09, 2013 5:54 pm
Gallery: 9 images
Brett
I did not know that cheers man unless I just clean my sensor and bolt it to the 90 mm housing ? That way I probly won't need to tune the car
Posted: Tue Jul 09, 2013 6:36 pm
Ride: 1993 EB XR8
You would need to tune it. For the bigger sensor.
Posted: Wed Jul 10, 2013 2:30 am
Yep. Dropping the sensor in a bigger housing throws the calibration out. With the Pro-M and other good aftermarket sensors they come with a transfer function curve (mass flow in kg/h vs sensor output voltage 0-5v) which you then program into your ecu via a flash tuner, j3 chip or quarter horse.
The only time its plug and play is if you get the maf calibrated for your injectors and ecu. By scaling the transfer function its still a bandaid solution.
Posted: Thu Jul 11, 2013 12:05 am
EFI Guru
Gallery: 28 images
Brett
You've already got an AU so you don't need to change the plug. I think the 90 is too big for your combo. The stock 70 will be fine, but then we've already been over this.
Posted: Thu Jul 11, 2013 7:58 pm
Gallery: 9 images
Dude do u know how long and many post I have looked through to find what you just posted, I all ready have the 73 mm maf with my original maf sensor in the housing seems to run ok:/
Posted: Thu Jul 11, 2013 8:12 pm
Gallery: 9 images
Yeah sorry xr9 you must be getin sick of my post! its crazy how much I've learned this side of the windsors. I obviously miss read the post saying and au plug will fit lol,
It is currently Mon Jan 13, 2025 9:22 pm All times are UTC + 11 hours
