Diff on Ford AUII
Page 1 of 1 [ 10 posts ]
 Post subject: Diff on Ford AUII
Posted: Fri Oct 06, 2017 8:36 am
Ride: Ford Falcon AU 2000 Series II
Hi,
I am about to do an oil change on the rear diff on my Ford AUII.
Can someone let me know if its a normal diff and what Diff oil to use. I doubt if I have a limited slip diff. It's all live axle.
Thanks.
 Post subject: Re: Diff on Ford AUII
Posted: Fri Oct 06, 2017 5:09 pm
most likely a "normal" diff lol .... should have a sticker [or what's left] on the drivers side of diff. this will tell you a bit more about the diff/type & ratio.
Posted: Fri Oct 06, 2017 11:02 pm
I'm sure its a normal stock standard diff.
I'll see if I can find any stickers on the axle, hopefully it's still there and legible.
Posted: Mon Oct 09, 2017 11:10 pm
If not, send me a VIN for your car if you can.
Posted: Tue Oct 10, 2017 1:30 am
Papa Smurf,
I'll have a look for the VIN if need be, I'll jack the car up tomorrow and see if I have the sticker still attached to the live axle.
Posted: Tue Oct 10, 2017 8:12 pm
Ride: 2003 BA N/A XR6 ute
Penrite Pro Gear 80w-140 if LSD. Jack both wheels up and spin one by hand. If they go opposite ways not LSD. Some IRS have High Performance diff tag too, run LSD oil in them.
http://www.penriteoil.com.au/products/p ... 0-full-syn
2003 Narooma Blue XR6 ute - NOW WITH 6 SPEED! - Underdrives, Hyperflow + Terry pipe + turbo snorkel, 4490's, Venom H/F Cat, 2.5" Redback, BF Turbo T56 conversion, H/D Turbo clutch, custom tailshaft, 3.89 LSD
Posted: Tue Oct 10, 2017 8:55 pm
I could not check them today, will check Wednesday and see what it reads. The replaced axle came from a AUII Forte, so should be same as the one I orginally had. I removed the entire rear axle due to lot of noise. It was replaced with the other.
Posted: Sat Oct 21, 2017 4:26 pm
Finally had a chance to check the axle details.
Sticker says RATIO 3.08:1 WA4AC WR2A-4006-AC
Would this be normal diff?
So what diff oil should I use considering I drive over 1000klm per week. One day in the week I drive 420klm return trip.
Thanks
Posted: Sat Oct 21, 2017 7:33 pm
standard factory fitment to the base models I believe
Posted: Sat Nov 04, 2017 1:47 pm
Does anyone know what size bolt hole is on Ford AU11?
I need to get the right size hole punch for oil joint paper before I pull the diff cover off.
Thanks
Users browsing this forum: No registered users and 22 guests
It is currently Mon Jan 13, 2025 1:34 am All times are UTC + 11 hours
