Clutch shudder problem on EL
 Post subject: Clutch shudder problem on EL
Posted: Fri Jan 14, 2005 11:23 am
Ride: R32 GTR
I'm using an EA flywheel and clutch (3 bolt setup) and after installing it, it was fine for a week. Slowly over a day or two it started to shudder and got so bad that it simply was almost impossible to take off without chirping the rear wheels because of excessive shudder. I initially thought a bolt fell out of the pressure plate but thats not the case, someone suggested there might be oil on the friction plate. So one attempt to take off in fifth gear from standstill for about 10 seconds fixed it completely. A bit of smoke and that awful burning clutch smell hung around for a minute or two and then it went back to perfect.
Fast forward a few days and the shudder has returned. I smoked the clutch up once more but nowhere nearly as much as the first time, most shudder went away. Its come back today.
What could be the problem and how would I fix it?
Posted: Fri Jan 14, 2005 11:42 pm
Gallery: 14 images
Ride: BA XR6 Turbo
Power: 175 rwkw
I have a similar problem with my EF!
The clutch is only a few months old and after replacing the cable this seems to be the next problem on the list...
I did the smoke it up thing too (by mistake!) but yeah a few days later and its's back
Posted: Sat Jan 15, 2005 9:18 pm
Gallery: 20 images
Ride: 03 BA Fairmont
logically, leaking rear crankcase seal/gearbox seal??
Regards,
Punnisher_42
_____________
2003 BA Fairmont - Stock standard
1994 U13 cough Nissan Cough Bluebird
Favorite Quotes:
"Sportwagon = homo-erotic wank-fest." - downingj
Posted: Mon Jan 17, 2005 10:12 am
Ride: R32 GTR
Thats what I would have thought, there is no oil inside the bellhousing and I removed the stone plate on the lower half of the gearbox bellhousing to see if there was any oil on the engine side of the flywheel - none at all.
This is sh.ting me more than the dinosaur cable clutch.....
It is currently Mon Jan 13, 2025 2:03 am All times are UTC + 11 hours
