Rattling noise from rear shocks after lowering
Page 1 of 1 [ 6 posts ]
 Post subject: Rattling noise from rear shocks after lowering
Posted: Thu Mar 24, 2005 7:40 pm
Ride: EL Futura
Since I've lowered my car, my rear shocks have been making a rattling noise.
I have narrowed down the noise to being the little rubber that goes ontop of the shocker, and is ment to slide up and down with the shocker. What happens when it starts rattling (really more of a knocking noise) is the rubber gets stuck at the top of the shock rod, and causes all susspension noise to echo through the protective cover.
At first this was because the rubber was put in upside down, allowing it to get caught on the lil nobby bit at the top.
But even now I have turned it over to the right way, and that lasted for all of about 4 days, before the rattle is back.
Any ideas?
5 Speed EL Futura
Stock as a rock*
A1 Oils - Synthetic lubricants: www.a1oils.com.au
* A rock that has been Alted
Posted: Thu Mar 24, 2005 9:57 pm
Ride: 2008 WQ Fiesta XR4
It'll be your lower shock bolts causing the rattle. They need to be bloody tight other wise the shock can move sideways the tiniest bit and there is your knock.
2008 WQ Fiesta XR4
2007 LS Focus CL
Posted: Thu Mar 24, 2005 10:00 pm
Gallery: 29 images
Ride: VU SS
Aha! So that's what that bloody noise is!
Time to tighten that up methinks!
EF Fairmont now Sold!
Guides: {DESCRIPTION}|{DESCRIPTION} |{DESCRIPTION}
Posted: Thu Mar 24, 2005 10:38 pm
Ride: EL Futura
Fairmont1998,
Thanks for your input, I'll check that out tomorrow, nothing better to do.
Cheers.
5 Speed EL Futura
Stock as a rock*
Posted: Thu Mar 24, 2005 11:32 pm
Ride: BF Typhoon
It is amazing how many times you hear of peoples rear shocks knocking; my current ones are also; i tightened them n they were fine; altho the other day i think i heard them again over a speedhump - i think it can wait till they are put aside for some lowered jobbies but.
BF Typhoon, Dejavu - 6sp Auto, Leather, Sunroof, 19"s, Electric Pedals, Tint, FPV Sports Wheel, FPV Mats.
Posted: Fri Mar 25, 2005 12:21 pm
Ride: EL Futura
Awesome!!
That was exactly what my problem was! Thanks so much. It was hard tightening the bolt with the car on the ground fitted with superlows, but I managed! Thanks!
Daniel, I agree about how often you hear knocking shocks, I can't believe it was so simple to fix! I think the knock in the shock is what attracted the cops attention when he TRIED to defect me for being too low. I was 2mm above the limit!
5 Speed EL Futura
Stock as a rock*
Users browsing this forum: No registered users and 29 guests
It is currently Mon Jan 13, 2025 2:54 pm All times are UTC + 11 hours
