Huss_mos |
Hey guys I searched and found some info though they are all older posts and not sure if anybody is paying attention to them and not what I'm asking specifically
I've done 90% of my aut to manual conersion -ECU changed to a manual 6 speed one out of a BA -6 speed installed with new heavy duty clutch + flywheel -Manual tailshaft installed -Pedals installed and hooked up -clutch fluid reservoir installed -shifter installed and selcts gears find -speedo cable and reverse lights spliced into the 4 speed loom My issues are -break lights will not turn off when car is on -car will not start with the key I have to put it in ignition and cross the relay -car WILL NOT go over 2.5k RPM -Blowing a bit of black smoke NOTES: I had a custom tune on the old ECU and unmarried my SCT Tuner from that and uploaded the tune to the manual ECU SUCCESSFULLY I had a guy come out and reprogram the ECU to the immobiliser and he said that was all there is to do. Any Pointers will be greatly appreciated |
