bondy99 |
Age: 65 Posts: 1128 Joined: 13th Sep 2010 Ride: Ford Falcon AU 2000 Series II Location: Crestmead |
Question regarding compatibility.
I have a Ford AU2 (Forte), build June 2000, went to the wreckers to find another one to replace mine. I found one that was basically intact but came from a Ford AU (Forte) Build February 2000, not an AU2. I'm wondering whether the one from an AU will work as is on an AU2 or will there be a problem? Thanks, Peter |
Mad2 |
{USERNAME} wrote: Question regarding compatibility. I'm wondering whether the one from an AU will work as is on an AU2 or will there be a problem? Thanks, Peter Hi, my understanding is AU2/3 are compatible with the AU1 being hit & miss. have tried a AU1 in the AU2, but some parts of the cluster were NOT compatible between the two. i don't remember which parts sorry. |
bondy99 |
Thanks Mad2,
I'll have to see if there is an AU3, at the wreckers, all the wrecks I've seen so far have been stripped. |
Mad2 |
what's wrong with the one you have??
bondy99 |
Mad2,
The problem with the one I currently have is that at night I cant read the odometer so I can check DTE. I've replaced the globes at the back of the odometer, they lit up for 2 weeks, but after that, they no longer light up, even with replacing with original and aftermarket globes. |
